  3. Netlist without using meastro / ade
  • Views 7738
idann
idann over 3 years ago
I want to create a netlist of an analog config view. is there a way to do it without going thru Maestro/ade, like from ciw/skill/shell?
Reason: I just need to know that the design is netlistble and want to avoid the need to creating unnecessary cells.
    Andrew Beckett over 3 years ago +1
    Netlist for which simulator? If it's AMS then you can use "runams" to do this. If it's for (say) spectre, then you would do: ocean then these SKILL functions: simulator('spectre) design("lib" "cell…
  • andrew2323
    andrew2323 over 3 years ago
    You will get the answer soon
    ocean
    simulator('spectre)
    design("lib" "cell" "config")
    createNetlist()
  • idann
    idann over 3 years ago in reply to Andrew Beckett
    Thanks that is exactly what I needed Slight smile
