  3. Monte Carlo analysis info missing from Spectre output l...
  • Views 6896
Monte Carlo analysis info missing from Spectre output log
RuihW
RuihW over 3 years ago
Hello, I'm running Monte Carlo simulation using ADEGXL but getting the following errors. It seems that the Spectre output log has some issues?
It's a simple DC analysis and it worked in Test Editor. Besides, Monte Carlo was working a few months ago. Is this a configuration issue that I should contact with my server admin?
    Perhaps you haven't included the statistics block in your simulation models and so there's no variation?
    Does the spectre log show that it ran Monte Carlo OK?
    Which IC sub-version and Spectre sub-version are you running?
