  3. maestro results copied to another maestro results histo...
  • Views 9112
maestro results copied to another maestro results history
Pirate King
Pirate King over 3 years ago
Say you had to split up corner runs amongst multiple explorer maestros and run all in parallel but then at then end would prefer to have all the results in the same golden version and delete all the others, is this possible? I have tried to copy the results directory of 1 run into the golden maestro results area but explorer does not show it in the history list.
  • Pirate King
    Maybe multiple people working in same project area with different versions of the golden maestro and only they can retrieve their own results for reporting. If all these results could be brought back into the same golden maestro and all others deleted leaving a tidy organised database.
    Andrew Beckett over 3 years ago in reply to Pirate King
    This is a bit of an odd thing to do - separating into different maestro views - but I think you can do it with ADE Assembler, which has more history management (saved results in Explorer are kind of lightweight histories, and there's less capability provided in order to keep ADE Explorer simpler - you normally only deal with a single history at once in Explorer).
    In essence you'd do an Import History for each of the histories (you can import from other maestro views too), and then you can multiply select the histories and do Merge and load to active (or this can be done with reference histories too) to combine the results together.
