  3. Maestro - saving output expressions to different folder...
  • Views 2700
Maestro - saving output expressions to different folder by default
firebolt2
firebolt2 over 3 years ago
Is there a way to save outputs by default to different directory than workarea, instead of chosing the folder every time? When I click on save button, it should directly save outputs to desired path. In this way I will keep my workarea clean.
    Not as far as I know.
  • firebolt2
    firebolt2 over 3 years ago in reply to Andrew Beckett
    Not on just one click, but instead of browsing folder, it should save outputs directly to desired path when clicked on OK. Can we do it with cdsinit?
    Andrew Beckett over 3 years ago in reply to firebolt2
    Still no. The field is filled out with a default file name outputs_libName_cellName_viewName.csv (lib/cell/view of maestro view). There's no control over the path, or how this is formed - it's always done this way.
