  3. Bias setting of spectre
  • Subscribers 129
  • Views 5308
shareemotion
shareemotion over 2 years ago
Using Specter, we are extracting the capacitance information of the mosfet using captab.
I connected the source to gnd and set it to 0V, but when I displayed it in verilog-a, it showed 0.5V.
I reviewed the netlist and va files several times, but no unusual features were found.
Why does the specter itself set the voltage like this?
    You’ll need to share more information than this - what does the circuit look like? A picture of the schematic and also sharing the netlist would help. Also, what is in the Verilog-A model? I’m sure there’s a reason, but guessing what it might be from so little data is almost impossible…
