  3. LVS mismatch when transistor body is not detached/integ...
  • Views 2613
LVS mismatch when transistor body is not detached/integrated
supriyo1985
supriyo1985 over 3 years ago
I have two layouts of a single-stage fully differential amplifier. The only difference is that the body terminal of the transistor in the left figure is detached, while on the right, it is configured as ‘none’ (pls see the dropdown).
The right layout has LVS mismatch, shown in the bottom figure. I need to figure out a way to not use detached/integrated body type to be able to share the diffusion region. Any help would be appreciated.
Regards
Supriyo
  • supriyo1985
    I have fixed the issue. The body contact was not drawn correctly. Thanks anyway.
    Regards
    Supriyo
