  3. Difference between PM frequency from stb and result fromcalculato...
  • Subscribers 136
  • Views 9347
Difference between PM frequency from stb and result fromcalculato?
zuiying
zuiying over 2 years ago
Hello,I am using stb to simulate my OTA. The schemetic is as follows.
The setting in stb and simulation results are as follws.
I want to know unity gain bandwidth. I direct plot the PM frequency and it tells me 6.899MHz.
But when I use calculator to calculate the the zero crossing point of the gain curve,it tells me 7.512MHz.
This two values is not very close. Which one is correct or more accurate? Thank you!
  • zuiying
    My virtuoso version and spectre version are as follows.
    Andrew Beckett over 2 years ago in reply to zuiying
    Both versions are very old, but I think the problem here is how the interpolation is done is different between how it's done in the simulator and how it's done using the method you chose. There's probably a high-degree of potential for interpolation error because you don't have many points in the waveform (40 points on a log axis between 100k and 10G. Maybe try simulating with (say) 40 points per decade and seeing the difference.
    I believe (from a discussion I had and a change request I had a few years ago, CCR 1033825) that the stb analysis does a more realistic interpolation than doing it in post-processing, and particularly bad was the phaseMargin function which was doing linear interpolation on the magnitude (rather than the log gain and log frequency). However, I've not checked detail exactly what stb analysis reports itself (note that you can get that number directly from the simulator - it's in the output database). With more points I'd expect them to be similar and converge.
    If I had the time I'd do more investigation... (sorry!)
  • Lahsiv902
    Lahsiv902 over 2 years ago
    Use the calculator for the unity gain frequency. The built-in function for unity gain frequency is not accurate.
    The PM value from the stb analysis report is more accurate.
  • zuiying
    zuiying over 2 years ago in reply to Andrew Beckett
    Thank you!
  • zuiying
    zuiying over 2 years ago in reply to Lahsiv902
    Thank you!
