  3. XNOR Gate Operation Issue in Cadence
  • Subscribers 129
  • Views 6371
Maria98
Maria98 over 2 years ago
Hi
I wanted to XNOR the data stream with its one-bit delayed stream. But not getting the correct values at some highlighted intervals. Any idea what could be the mistake? The delay block setting is of 1ns with a 50 ohm characteristic impedance.
thanks
    You didn't mention which library this xnor comes from (it looks like xnor_gate from ahdlLib though). If it's that view, the problem is almost certainly that you've set the threshold for the input (vtrans) to a ridiculously small value - it should be more like 0.5V whereas you've set it to be some minuscule fraction of a variable per (presumably a period in time).Your tdel is probably a bit short too, but I think it's the vtrans that is the issue. Set it to 0.5 and see what happens.
  • Maria98
    Maria98 over 2 years ago in reply to Andrew Beckett
    Dear Andrew
    XNOR gate is from ahdlLib. It solved setting Vtrans properly. Thanks for the correction.
