  3. Any way to set a default value for the design variables...
  • Views 6792
Any way to set a default value for the design variables in ADE explorer
jason1127
jason1127 over 2 years ago
When doing simulation, we may modify the variable value from time to time. Normally, we save the design target value in the maestro view when a project was done. But sometimes, we may forget to change the value back to design target. So after sometime, when came back to the design, or someone else want check the design, we don't know what's the design target value for the variables. Of course, we can use document to record it. However, is there any feature/way we can set a default value to the variables?
    Andrew Beckett over 2 years ago +1
    If you use Variables->Copy to Cellview, it stores them on the cell used for the test (it's a misnomer - they are stored in the cell properties in a property called designVarList ). You can get them back…
    If you use Variables->Copy to Cellview, it stores them on the cell used for the test (it's a misnomer - they are stored in the cell properties in a property called designVarList). You can get them back with Variables->Copy from CellView
