  3. Using Ocean Script in cross corner simulation in Assemb...
  • Subscribers 130
  • Views 6559
Using Ocean Script in cross corner simulation in Assembler
Abhrarup
Abhrarup over 2 years ago
This is a very basic doubt because the same code is not working with the ICFB version i am using.
I want to add ocean script to ADE-ASSEMBLER and capture data across corner and store them in separate files. I have one doubt and facing one problem -
1) openResults("./psf") is NOT working : the path is not found by the compiler. I do not want to provide an exact path since this would require me to change the file for each run becase the directory gets updated every run
2) If i get to make 1 run, then i want to accces a bunch of data from each run and store them in a different files for each corner. How can i do this ?
ICFB  version : CDS: virtuoso version 6.1.8-64b 08/09/2022 19:25 (cpgsrv11)  , subversion : sub-version  IC6.1.8-64b.500.27
Thanks!
Abhrarup
    ShawnLogan over 1 year ago
    Dear Abharup,
    On several occasions in this Forum, I have provided an ocean script that will traverse the Assembler hierarchy for corner simulations and access each of its simulation corners. For each corner, you may access the results for that corner and do whatever post-processing you want. You may write the data to one or more files. For example, you may want to access a single result from each corner simulation and summarize the results for all corner simulations in a single file.
    The script contains comments so you may modify it for your use. The basic script is in the Forum post at:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/43159/way-to-use-skill-script-to-save-waveform-into-a-file-in-ade-xl-run
    Modify the maximum number of corners to the number of sweeps in your analysis and provide the paths to your results directory as well as the name of your test in the sample code in the lines:
    base_results=strcat("<path_to_your_results>/maestro/results/maestro/Interactive.X/")
    Note: the code in the year old post shows the ADE-XL path - please use the slightly different line above for the Maestro results
    sub_dir = strcat("<Maestro test name>")
    Place your data access commands after the comment:
    ; Load waveform "vc"
    The data access commands for the operating point information are provided in the prior URL I referred you to regarding accessing operating information with ocean.
    The sample script I provided is for a transient analysis and you may need to change it to the type of results you wish to access. One of the two possible ASCII files in the ocean script contains the results for all the corner runs and hence will have {number_of_corners)+1 lines (+1 since you can include a header).
    I hope this helps Abhrarup,
    Shawn
