  3. Way to use SKILL script to save WAVEFORM into a file in...
  • Views 25718
Way to use SKILL script to save WAVEFORM into a file in ADE-XL Run
RFStuff
RFStuff over 6 years ago
Dear All,
I have to run a multi-corner ADE-XL simulation and I have to save the waveforms into separate files.
Later I can use these files in pwl source for other test-benches. This way I can fasten the simulation for later cases.
But, I am wondering how I can save the waveform (NOT manually) into files through ADE-XL run. Can it be done through SKILL script.
Could anybody please help me in this regard.
Kind Regards,
    ShawnLogan over 6 years ago
    Dear rfstuff,
    I am sure this can be accomplished multiple ways...two or three methods that I use follow.
    1. Write a short ocean script to traverse the ADE-XL directory structure, open each set of results, use getData() to access the waveforms of interest, and write the waveforms you want to text files using either an fprintf() statement or OcnPrint(). I have attached an ocean script that might serve as a template.
    2. Alternatively, you can plot all the corner results on one graph in ViVa, select them all and, using your right mouse button, "Send to...Export..." or "Send to...Table" . The former might be best if the number of time points in the waveform is large.
    I am sure many other very skilled designers have other methods of accomplishing your goal.
    Shawn
    Fullscreen sample_ocean_script.txt Download
    ; Main routine
    simulator('spectre)
    base_results=strcat("<path_to_your_results>/results/data/Interactive.0/")
    sub_dir = strcat("<ADE-XL test name>")
    TSTOP = 30e-09
    init_val = 1
    final_val = <number_of_corners>
    sim_case = init_val
    while( sim_case < (final_val + 1)
    printf("sim_case = %d\n" sim_case)
    sprintf(sim_case_val "%d" sim_case)
    ; Define unique output file for each ADE-XL set of simulation results
    fname = strcat("<your output file name>" "_" sim_case_val ".csv")
    fp_params = outfile( fname "w")
    results=strcat( base_results sim_case_val sub_dir "psf")
    printf("Results directory\n%s\n" results)
    openResults( results )
    selectResult( 'tran)
    ;ocnPrint( ?output "outputs.txt" outputs())
    ; Load waveform "vc"
    vc = getData("/vc" ?results "tran" ?resultsDir results)
    tstart = 0
    tstop = TSTOP
    sim_time = tstart
    delta_t = (tstop - tstart)/1000.0
    while( sim_time < (tstop + 0.10*delta_t)
    fprintf(fp_params "Time,vc\n")
    fprintf(fp_params "%1.8e,%1.8e\n" sim_time value( vc sim_time))
    sim_time = sim_time + delta_t
    ) ; end while loop
    close(fp_params)
    sim_case = sim_case + 1
    ) ; end sim_case loop
    exit()
    Andrew Beckett over 6 years ago in reply to ShawnLogan
    One way could be to use the code in this thread. Load this file in your .cdsinit using:
    load("abDumpWaveform.il")
    and then add an output expression in ADE XL such as this:
    abDumpWaveform(VT("/outdiff") strcat(openResults() "/dump.txt")) && 1
    The VT() would be whatever signal you wish to save, and the "dump.txt" is the file name you want (it will save this at the same level as the netlist and psf dir for each simulation point in ADE). The && 1 part is just to ensure the expression returns a number to prevent any errors.
    If you then run a simulation and go over the point you're interested in and do Right Mouse->Open Terminal you'll then see there's a dump.txt file in that directory.
    Hope that helps?
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Thanks a lot Shawn and  Andrew.
    Kind Regards,
  • RFStuff
    RFStuff over 6 years ago in reply to RFStuff
    Dear Andrew,
    We can save N multiple waveforms in a single file.
    abDumpWaveforms("data.out" VT("/c") VT("/z") VT("/a") ?format "%-10g" ?separator ",").
    But, is there an efficient way we can have the single file to be used in a testbench for N vsources ?
    Kind Regards,
    Andrew Beckett over 6 years ago in reply to RFStuff
    See my response in your other post (I would have answered this sooner but have been away this week).
