  3. deepprobe to access systemVerilog variables
  • Views 6582
ElZorro
ElZorro over 2 years ago
Hello Andrew,
I am referring to a post which is locked:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/57152/deepprobe-to-access-veriloga#
I am trying to use your suggested model to probe an internal variable (which is inside a systemVerilog module) and connect it at the top level to a resistor.
I am using ADE Assembler, simulator=ams and I am figuring out how load the required command-line options in the GUI.
I created a file CommandLineOptions.scs with the following content:
-va,cgav_in_contrib
and I am trying to load that file doing
Test/RightMouseButton/Options/AMS simulator/
Include Option Settings/
Include Options Tab/
Files on xrun command line:  CommandLineOptions.scs
But this doesn't seem the correct location or the correct syntax.
I get the following error:
xrun: *E,SPCERR: The program encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
amsspice: *    ERROR (SFE-874): "/.../env/CommandLineOptions.scs" 1:
Cannot run the simulation because syntax error `Unexpected operator "-"' was encountered at line 1, column 0. Correct the syntax error and rerun the simulation.
Thank you for your help!
