  3. Is this a valid function getEnterRemoveNetProbe()?!
  • Views 6562
BitanMallik
BitanMallik over 2 years ago
Which function is used to set "remove probe" and "remove all probes" in schematic?!
and, then i will use this in my Bindkeys?!
Thanks!
    Andrew Beckett over 2 years ago +1
    Very simply, use Options→Log Filter and turn on the Accelerated Input item. Then in the schematic editor use Create→Probe→Remove Net or Remove All and you'll see in the CIW that the functions are: geEnterDeleteNetProbe…
    geEnterDeleteNetProbe()
    geDeleteAllProbe(getCurrentWindow() t)
    (note the title of your post has almost the right function for the first, but with a small typo - "get" instead of "ge").
