  3. RLC S-Parameter Analysis vs Clarity 3D Inductance-Capacitance...
  • Views 7067
RLC S-Parameter Analysis vs Clarity 3D Inductance-Capacitance Extraction Results Comparison
Amir2162
Amir2162 over 2 years ago
Hi, I would like to ask what is the reason why RLC S-Parameter Analysis in Cadence Virtuoso using FIT file generated by Clarity Full Wave Extraction is more accurate than the Inductance Clarity 3D Layout Extraction and Capacitance Extraction.
I assume it is due to the frequency sampling used in Full-Wave Extraction but maybe there is other reasons?
Thank you very much.
    I suggest you contact customer support (please submit a support case after logging in) to clarify the details of your setup and the difference you're seeing.
