  3. maestro Waveform renaming
  • Views 6615
wangyunxin
wangyunxin over 2 years ago
I named the signal in the name column in maestro, but when I right-click the signal and plot it,it still shows the name in the details column.In addition, I did not find the option of renaming when I right-edited this waveform in the viva window. May I ask what should I do if I want to display the name of this waveform into the name column in Maestro
    This is not possible currently. The output name is not used for signals - there's a Cadence Change Request (CCR) 1175673 asking for this with a few duplicates; I suggest you contact customer support (submit a support case after logging in) asking for a duplicate to increase the likelihood that this will be enhanced sooner rather than later. Currently the name is only used for non-signal outputs.
    The workaround is to add an expression IT("/L2/MINUS") and name that.
