  3. Maestro can't save current with "WARNING (ADE-1063): The...
  • Subscribers 136
  • Views 2361
Maestro can't save current with "WARNING (ADE-1063): The output with same signal '***' is already defined."
wangyunxin
wangyunxin over 2 years ago
I tried to save the vin port current of I200 instance (as shown by the arrow in the figure).and in maestro In Maestro I hit Output - To be Saved- select on design and then in the schematic I clicked on the port in the picture1,But there was no signal from the Maestro
So I tried to save the other port current signals and changed their detail column to I200/vin,after do that,In the CIW window I received the following prompt "WARNING (ADE-1063): The output with same signal '/I200/vin' is already defined."
So I searched for /I200/vin in the detail column and did not find any stored current signal.
How to solve it? It would be annoying to have to recreate a Maestro simulation
  • wangyunxin
    help plz
    Andrew Beckett over 2 years ago in reply to wangyunxin
    wangyunxin said:
    help plz
    If this is urgent, please contact customer support. That's what it's for (these forums are a community resource and people answer in their spare time, including those of us that work for Cadence).
