  3. ADE Matlab Integration prevent deletion of Log files
  • Views 6085
qq123456
qq123456 over 2 years ago
Howdy,
I'm trying to do some debugging of my Matlab code used with the Matlab Integration.
The Matlab output, which would normally go to the terminal (in the integration there is of course no terminal) gets sent to a file name cdnsMatlab_<pid>.log
where <pid> is the PID of the Matlab session.   This is great, and I can see this file growing at the end of each of the calls to Matlab as I run over the various corners.
However, when all the processing of the data from the corners is complete, the log file, cdnsMatlab_<pid>.log changes the first line from:
SkillEvalManager:ctor
to
SkillEvalManager:dtor
and then deletes all the rest of the output.
Is there a way to prevent the deletion of the output in the cdnsMatlab_<pid>.log file, perhaps an environmental variable?
    Andrew Beckett over 2 years ago +1
    This file normally only gets created (I think) if you have _ADEXL_MATLAB_DEBUG set. I would advise you to contact customer support about this - I've normally used a different approach to debug issues with…
    This file normally only gets created (I think) if you have _ADEXL_MATLAB_DEBUG set. I would advise you to contact customer support about this - I've normally used a different approach to debug issues with MATLAB, but not using this env var, and neither this nor the variable I use are public... so not really something we would normally advertise in a public forum (mainly because it might change in future).
