  3. HB simulation with temperature update after each run
  • Views 6689
Martinsh
Martinsh over 2 years ago
Dear Sir,
I'd like to run an HB simulation with temperature update after each run. Just like this
1) Set initial temp=27C
2) Run HB simulation.
3) After HB simulation, calculate Trise=(Pdc-Prf)*Rth. Here, Trise is die temerature rise caused by power to heat. Pdc is the total power. Prf is RF output power. Rth is thermal resistance of die.
4) Update simulation temperature, temp = temp+Trise. Then GoTo step 2) and re-run HB simulation with the updated temperature. If Trise<1, stop simulation.
Can spectrue support such simulation?
Best regards,
Martin
    Martin,
    Spectre itself can't do this within the simulator, but it would be very easy to do with a run plan in ADE Assembler. In this example I have a single test "Setup" which runs a two-tone hb analysis. One of the outputs is harmPower which is the output of one of the harmonics in dBm. I then set the run plan up like this to have two runs:
    As you can see, the temperature is set to be a function of the harmPower output (retrieved using calcVal, with ?run "First" to retrieve from the first run in the run plan).
    The calcVal sets a dependency between the runs, and it is correctly passing the temperature for the second run based on an output of the first. The calculation in this example is completely made up (just so I could see an effect); I'll leave you to adjust to be your actual calculation. Of course, the new temperature could be an output of the test itself which would make the variable setting in the run plan simpler, and easier to observer in ADE.
  • Martinsh
    Martinsh over 2 years ago in reply to Andrew Beckett
    Andrew,
    Thanks. I will try it.
    Best regards,
    Martin
