  3. Verilog-A syntax error with user-defined function and if...
  • Views 9738
Verilog-A syntax error with user-defined function and if-else statement
gjeong35
gjeong35 over 2 years ago
I want to make ELU function in the verilog-A code, but it shows syntax error continuously. But the Verilog-A document says that this is the correct syntax, so I would like to ask you what should I fix.
module myVerilogAmodel(d, g, s); //* input parameters
analog function real ELU;
real k;
real alpha = 1.0; // Setting alpha value
begin
ELU = (k > 0) ? k : alpha * (exp(k) - 1);
end
endfunction
analog begin
Vg = V(g) ;
Vs = V(s) ;
Vd = V(d) ;
Vgsraw = Vg-Vs ;
Vgdraw = Vg-Vd ;
if (Vgsraw >= Vgdraw) begin
Vgs = ((Vg-Vs) - MinVg) * normVg ;
dir = 1;
end
else begin
Vgs = ((Vg-Vd) - MinVg) * normVg ;
dir = -1;
end
Vds = (abs(Vd-Vs) - MinVd) * normVd ;
Lg = (L -MinLg)*normLg ;
hc1_0 = ELU(-2.0581515*Vgs+1.1546319*Vds+0.59735364*Lg+0.7725613);
I wanted to find the Verilog-A version of the Cadence virtuoso solver, but I could not find it.
The error says:
 ERROR (VACOMP-1576):
"/nethome/gjeong35/iwo_transistor/LVIWO_nch_elu_elu/veriloga/veriloga.va",
line 57: Missing arguments for function ELU. Specify at least one
argument for a function.
ERROR (VACOMP-1240): "hc1_0 =
ELU(-2.0581515*Vgs+1.1546319*Vds+0.59735364*Lg+0.7725613)<<--? ;"
line 88: Argument count mismatch for function `ELU'. The number of
passed arguments must match the number of arguments the function
requires.
ERROR (VACOMP-1563):
line 88: Encountered invalid type conversion for `hc1_0' (`*undef*' to
`real'). Check the validity of conversion and try again.
ERROR (VACOMP-1240): "hc1_1 =
ELU(-1.2754086*Vgs+1.0171142*Vds+-0.18343183*Lg+0.44029102)<<--? ;"
line 89: Argument count mismatch for function `ELU'. The number of
requires.
The spectre version is 23.10.053. Thank you for your help in advance!
    First of all, posting your question in an appropriate forum is wise (the Feedback, Questions and Suggestions forum is for issues with the forums themselves, not for technical questions).
    Secondly, posting something complete enough to reproduce the problem helps. There was a lot missing from your code to make it run.
    Anyway, the key issue is that you didn't declare any input parameters to the ELU analog function so it wasn't expecting any arguments. You should have defined it like this:
     input k;
     real k;
     begin
     end
     endfunction
    I'm not sure what the "Cadence virtuoso solver" is that you're referring to (there is no "Cadence virtuoso solver"), but this will be an issue in any version of Spectre because it isn't correct according to the Verilog-A/AMS LRM.
