  3. Liberate license issue
  • Views 10967
VardhanPES
VardhanPES over 2 years ago
Hi Greetings,
I am trying to invoke the Liberate tool but I constantly get this error message:
/////////////////////////////////////////          terminal     //////////////////////////////////////////////
ERROR (LMF-11005): License call failed for feature LIBNG_NEXT, version 1.000 and quantity 1. The license server search path is defined as <none>. The FLEXnet error message is as follows,
FLEXnet ERROR(-5, 234, 0): No such feature exists.
Run 'lic_error LMF-11005' for more information.
INFO (LIB-710): (Jan 23 12:51:08): Failed to check out a key for 'LIBNG_NEXT' (version 1.0).
I have followed the instructions mentioned in the blog post:  https://community.cadence.com/cadence_blogs_8/b/di/posts/library-characterization-tidbits-accelerating-signoff-with-liberate-installation-and-licensing-part-1
and have set all my env variables
//////////////////////// ///////////////////    cshrc file    /////////////////////////////////////////////////////////////////////
setenv CDS_Netlisting_Mode Analog
setenv QRC_ENABLE_QRCRACTION "1"
setenv CDS_AUTO_64BIT ALL
setenv CDS_AHDLCMI_ENABLE YES
setenv ALTOS_64 "1"
setenv EDITOR gedit
setenv LM_LICENSE_FILE 5280@xx.xxx.x.xx
setenv CDS_LIC_FILE $LM_LICENSE_FILE
setenv LANG en_US
################ Liberrate #############################
setenv LIBERATEHOME /home/install/LIBERATE201
and also followed up with part of the blog: https://community.cadence.com/cadence_blogs_8/b/di/posts/library-characterization-tidbits-accelerating-signoff-with-liberate-installation-and-licensing-part-2
and have checked that the version of both cdslmd and lmgrd is the same as required.
///////////////////////////////////////// Terminal //////////////////////////////////////////////////////////////////////////////////
# cdslmd -v
(cdslmd) FlexNet Licensing version v11.16.4.0 build 252457 x64_lsb
# lmgrd -v
lmgrd v11.16.4.0 build 252457 x64_lsb - Copyright (c) 1988-2019 Flexera. All Rights Reserved.
Yet I am not able to resolve the issue. How do I resolve the issue?
Regards!!!
  • Guangjun Cao
    Guangjun Cao over 2 years ago
    I see you are using a Liberate 20.x release, which is for specific customers only. please use the latest 23.1 release.
    Guangjun
