  3. With large Verilog-A, SPECTRE fails to run
  • Views 5910
mfkasim1
mfkasim1 over 2 years ago
I have various Verilog-A models. With relatively smaller size Verilog-A, SPECTRE can successfully run the netlist simulation. It compiles the Verilog-A model the first time it's being used, and then for the next simulation, it will reuse the VA model without recompiling. However, with relatively larger Verilog-A model, SPECTRE seems to fail to compile the VA model without any error messages (the directory under `ahdlshibdbdir` only contains an empty directory with random names). How do I debug this and how to make SPECTRE to compile and run the simulation?
I am using SPECTRE in command line mode with command: `spectre +aps -mt -ahdlshipdbdir=/home/spectre_dir/spectre_ahdl/ -ahdllibdir=/home/spectre_dir/spectre_ahdl/ -ahdlshipdbmode=create_or_update netlist.cir`.
As an additional information, my Verilog-A model has more than 3000 parameters. Here is a simple example of my netlist file with the Verilog-A model included:
* A simple circuit *
* The device
.AHDL_INCLUDE model.va
NU1 10 0 mymodel
VPOS 10 0 SIN(2.5 0.1 2e2 0 9e1 33)
.OPTIONS abstol=1e-13 reltol=1e-4
.OPTIONS notation=sci colslog=1000
* Transient analysis command
.TRAN 0.02ms 20ms
.PRINT I(VPOS)
.END
