  3. Complex Port Value for transient results
  • Subscribers 136
  • Views 9981
EngrZM
EngrZM over 2 years ago
Hi
I am trying to run the transient analysis (Cadence Virtuoso ADE L) on an SnP file of a transformer layout. The s-parameter results are not consistent with the transient results. I am using complex impedance values at the input and output of the transformer. I tried different accuracy methods and algorithms available in transient analysis settings, but the results were not similar to the S-parameter results. I want to ask: is there any possibility that transient analysis is not supported with complex port values? The setup diagram is attached. please guide. Thank you
  • Frank Wiedmann
    Frank Wiedmann over 2 years ago +1
    I would say that it's very probable that complex port values are not supported in a transient analysis because a complex impedance that is constant over frequency does not exist in the real world.
    Andrew Beckett over 2 years ago in reply to Frank Wiedmann +1
    Thanks Frank. I thought I'd answered this yesterday but I don't see it (so maybe I didn't press the "Reply" button and got distracted). The help for "spectre -h port" makes it very clear that this is…
  • Frank Wiedmann
    Frank Wiedmann over 2 years ago in reply to EngrZM +1
    That surprises me. Anyway, you might want to take a look at the ideal_balun from analogLib, which is explained in detail at designers-guide.org/.../diff.pdf Oh, and if the output amplitude is your problem…
  • Frank Wiedmann
    The help for "spectre -h port" makes it very clear that this is only supported for frequency domain analysis (see the descriptive part at the top of the help, plus the specific documentation for the "x" parameter in the Port Parameters section). As Frank mention (and I tried to write yesterday) the issue would be that a constant complex impedance would not be causal in the time domain and is non-physical.
  • EngrZM
    EngrZM over 2 years ago in reply to Andrew Beckett
    Thanks Frank and Andrew for always being available to help cadence community.
    I got consistent S-parameter and transient results for the transformer (passive structure) simulation using port with real values only. But when i am simulating a differential amplifier, i am not getting transient results same as S-parameters. I am using 100 ohm input port (50 ohm imp of each transistor in the differential pair) and terminating it with 100 ohm port (differential output), as it works well with s-parameter simulations.
    Can we use 100 ohm single port for differential amplifier (50-50 matched) input/output in transient analysis?  For transient analysis i tried it in 4 configurations shown below:
  • Frank Wiedmann
    I looks like you forgot to add a gnd symbol to your circuit.
  • EngrZM
    EngrZM over 2 years ago in reply to Frank Wiedmann
    The results are same even with ground terminal at center.
  • Frank Wiedmann
    Oh, and if the output amplitude is your problem: specify the source amplitude in V instead of dBm, so that it does not depend on the port impedance. The internal source will have twice the value specified, so that you get the specified value when the load is matched to the port impedance.
