  3. no define_arc generated using write_template -truth_tab...
  • Views 841
no define_arc generated using write_template -truth_table
Mathieu Chene
Mathieu Chene over 2 years ago
I am trying to characterize a custom cell using LIBERATE 23.1.
I created a truth table  in a .tt file as it follow
* MODE= STD
* DELAY_TEM = delay_template1_3x3
* POWER_TEM = power_template1_3x3
* CELL = customCell
* INPUT_PINS= {WL BLGRD BLB XB}
* OUTPUT_PINS = {PPOut}
* BIDI_PINS = {Q}
* DUAL_IN = {BLGRD:BLB}
* TABLE =   WL BLGRD BLB  Q XB @ Q  POut
            0   X     X   0 X  @ 0     -
            0   X     X   1 X  @ 1     -
            1   0     1   0 X  @ 0     -
            1   0     1   1 X  @ 0     -
            1   0     1   X X  @ 0     -
            1   1     0   0 X  @ 1     -
            1   1     0   1 X  @ 1     -
            1   1     0   X X  @ 1     -
            X   X     X   0 0  @ -     0
            X   X     X   0 1  @ -     0
            X   X     X   1 0  @ -     1
            X   X     X   1 1  @ -     0
* TABLE_END
In my char.tcl file I deine the templates for delay and power and I use the commands
read_truth_table $rundir/truthTable.tt
write_template -verbose -truth_table $rundir/template_truthtable
However in the generated template file the define cell function doesnot contain any inputs/outputs
define_cell \
    -delay delay_template1_3x3 \
    -power power_template1_3x3 \
    customCell
and I have only define_leakage commands and no define_ arc
I do not understand what is wrong in my truth table to have this result.
Maybe you can help with this ?
Thank you in advance
Mathieu
