  3. Encountered a fatal error while compiling the ahdlcmi module...
  • Views 8156
Encountered a fatal error while compiling the ahdlcmi module library
Sami048
Sami048 over 2 years ago
So I am getting this problem, can anyone have any suggestion how to solve it ?
Error found by spectre during AHDL read-in.
ERROR (VACOMP-2354): Encountered a fatal error while compiling the ahdlcmi module library, "gnumake: warning: Clock skew detected". Check the log file input.ahdlSimDB//9a85597bf6b4f9e14073fddb7c48f87d.Memristor.ahdlcmi/Linux-64//..//ahdlcmi.out for details. Ensure that the system time on the server is correct and rerun the simulation.
ERROR (SFE-91): Cannot run the simulation because an AHDL compilation error occurred. Check the VACOMP error message above and correct the syntax error in the Verilog-A file. Next, rerun the simulation.
I checked the log file and it says the following
ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB//9a85597bf6b4f9e14073fddb7c48f87d.Memristor.ahdlcmi/Linux-64/ for Linux-64 with optimize using gcc on Tue Feb 6 18:34:33 EST 2024 [5.0]
ahdlcmicompile: Generating makefile
PATH: /opt/eda/cadence/SPECTRE181/bin:/opt/eda/cadence/SPECTRE181/tools/bin/64bit:/opt/eda/cadence/SPECTRE181/tools/bin:/opt/eda/cadence/IC618/bin:/opt/eda/cadence/IC618/tools/bin/64bit:/opt/eda/cadence/IC618/tools/bin:/opt/eda/cadence/IC618/share/oa/bin:/opt/eda/synopsys/sentaurus/O_2018.06/bin:/opt/eda/xilinx/standard/Vivado/2019.1/bin:/opt/eda/synopsys/syn/current/bin:/opt/eda/synopsys/customcompiler/current/bin:/opt/eda/synopsys/icc2/current/bin:/usr/lib/x86_64-linux-gnu:/opt/eda/cadence/IC618/tools/dfII/bin:/opt/eda/cadence/XCELIUM1809/bin:/opt/eda/cadence/INNOVUS181/bin:/opt/eda/cadence/GENUS181/bin:/opt/eda/cadtools/irsim-9.7/bin:/opt/eda/synopsys/wv/N-2017.12-SP1-1/bin:/opt/eda/synopsys/hspice/N-2017.12-SP2-1/hspice/bin//opt/eda/fpga/intelFPGA_pro/current/modelsim_ase/bin:/opt/eda/synopsys/current/syn/bin:/usr/local/go/bin:/opt/eda/mmi/current/bin:/opt/eda/synopsys/vcs-mx/current/bin:/opt/eda/synopsys/syn/current/bin:/home/khan4sn/bin:/usr/bin:/bin:/usr/local/bin:/opt/bin:/opt/eda/bin:/opt/eda/cadtools/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
LD_LIBRARY_PATH: /opt/eda/cadence/SPECTRE181/tools/giganta/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/mdl/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/mmsim/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/tcltk-8.4.20/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/inca/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/spectre/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/dfII/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/lib/64bit:/opt/eda/cadence/SPECTRE181/tools/lib:/opt/eda/cadence/IC618/tools/lib/64bit:/opt/eda/cadence/IC618/tools/lib:/opt/eda/cadence/IC618/tools/lib/64bit/Ubuntu:/opt/eda/cadence/IC618/share/oa/lib/linux_rhel60_64/opt:/opt/eda/cadence/IC618/tools/dfII/lib/64bit:/opt/eda/cadence/IC618/tools/sev/lib/64bit:/opt/eda/cadence/IC618/tools/hdf5/lib/64bit:/opt/eda/cadence/IC618/tools/lz4/lib/64bit:/opt/eda/cadence/IC618/tools/inca/lib/64bit:/opt/eda/cadence/IC618/tools/Qt/v5/64bit/lib:/opt/eda/cadence/SPECTRE181/tools/dfII/lib:/usr/lib/x86_64-linux-gnu
ERROR: ld.so: object '/opt-shared-v2/eda/cadence/IC618/tools.lnx86/dfII/../lib/64bit/libstdc++.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j8 -f GNUmakefile
gnumake: *** Warning: File `GNUmakefile' has modification time in the future (2024-02-06 18:35:58 > 2024-02-06 18:34:36)
Cleaning ./obj/optimize/5.0
rm -f -rf ./obj/optimize/5.0
gnumake: warning: Clock skew detected. Your build may be incomplete.
gnumake: *** Warning: File `GNUmakefile' has modification time in the future (2024-02-06 18:35:58 > 2024-02-06 18:34:37)
Compiling C file Memristor_ufunc.c (optimize)
Compiling C file Memristor_func.c (optimize)
Compiling C file Memristor_DcFuncDerLoad.c (optimize)
Compiling C file Memristor_DcFuncLoad.c (optimize)
Compiling C file Memristor_TranFuncDerLoad.c (optimize)
Compiling C file Memristor_TranFuncLoad.c (optimize)
Compiling C file Memristor_cmi_c.c (optimize)
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_ufunc.c -o obj/optimize/5.0/Memristor_ufunc.o || rm -f -f obj/optimize/5.0/Memristor_ufunc.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_func.c -o obj/optimize/5.0/Memristor_func.o || rm -f -f obj/optimize/5.0/Memristor_func.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_DcFuncDerLoad.c -o obj/optimize/5.0/Memristor_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/Memristor_DcFuncDerLoad.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_DcFuncLoad.c -o obj/optimize/5.0/Memristor_DcFuncLoad.o || rm -f -f obj/optimize/5.0/Memristor_DcFuncLoad.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_TranFuncDerLoad.c -o obj/optimize/5.0/Memristor_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/Memristor_TranFuncDerLoad.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -c Memristor_TranFuncLoad.c -o obj/optimize/5.0/Memristor_TranFuncLoad.o || rm -f -f obj/optimize/5.0/Memristor_TranFuncLoad.o
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -march=k8 -ffast-math -fno-unsafe-math-optimizations -O3 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include -I/opt/eda/cadence/SPECTRE181/tools.lnx86/cmi/include -c Memristor_cmi_c.c -o obj/optimize/5.0/Memristor_cmi_c.o || rm -f -f obj/optimize/5.0/Memristor_cmi_c.o
<stdin>: In function 'Memristor_DcFuncDerLoad':
<stdin>:492:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:211:49: note: expected 'struct MemristorInstData *' but argument is of type 'char *'
<stdin>:507:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:542:58: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:212:76: note: expected 'struct MemristorInstData *' but argument is of type 'char *'
<stdin>:553:58: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:586:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:601:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:689:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:714:59: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:878:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:893:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:930:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:941:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'Memristor_TranFuncLoad':
<stdin>: In function 'Memristor_DcFuncLoad':
<stdin>:326:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:209:6: note: expected 'struct MemristorInstData *' but argument is of type 'char *'
<stdin>:974:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:341:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:989:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:363:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:210:28: note: expected 'struct MemristorInstData *' but argument is of type 'char *'
<stdin>:374:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:394:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:409:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'Memristor_TranFuncDerLoad':
<stdin>:492:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'Memristor_AcLoad':
<stdin>:521:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:507:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:536:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:469:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1171:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1186:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:542:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:571:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:484:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:582:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:553:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1228:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1237:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:615:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:586:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1277:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:630:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1292:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:601:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:581:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:596:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:620:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:631:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:718:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:689:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:651:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:666:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:743:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1471:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1484:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:714:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1526:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1535:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1573:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1586:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:777:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:792:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:814:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:823:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:907:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:843:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:922:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:858:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1747:170: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:959:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:970:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
In file included from <stdin>:24:0:
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:2167:33: note: expected 'void *' but argument is of type 'long int'
ASL_FUNC_DECL_START extern long aslDevInterAddStaticElement( void *, double, struct ahdlFuncModeParam * );
<stdin>:1003:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1754:110: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1756:139: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1757:68: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:948:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1018:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1769:68: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>: In function 'Memristor_pPrintDescription':
<stdin>:1705:229: warning: implicit declaration of function 'msgWrite' [-Wimplicit-function-declaration]
<stdin>:1770:68: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:961:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1705:1588: warning: implicit declaration of function 'devGetRFinFreqDomain' [-Wimplicit-function-declaration]
<stdin>:1775:177: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1782:117: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:983:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1784:146: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1785:68: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:992:55: warning: passing argument 2 of 'Memristor_userFn_stp_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1010:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1023:56: warning: passing argument 2 of 'Memristor_userFn_sign_0' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1200:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1123:170: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>: In function 'Memristor_pGetInstanceParams':
<stdin>:1720:1576: warning: implicit declaration of function 'devGetInstKnotStatus' [-Wimplicit-function-declaration]
<stdin>:1215:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1257:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1266:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1140:177: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1306:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1321:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'Memristor_pDC_Load':
<stdin>:1737:3000: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast [-Wint-conversion]
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:2711:33: note: expected 'void *' but argument is of type 'long int'
ASL_FUNC_DECL_START extern void aslDevFillZeorDiagonalElemet( void *, int, unsigned int, struct ahdlFuncModeParam * );
<stdin>:1500:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1513:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1555:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1564:59: warning: passing argument 2 of 'Memristor_userFn_stp_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1602:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>:1615:60: warning: passing argument 2 of 'Memristor_userFn_sign_der_1' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'Memristor_pCompare':
<stdin>:1776:1064: warning: implicit declaration of function 'spReplaceMatrixPointer' [-Wimplicit-function-declaration]
<stdin>:1776:2725: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
<stdin>:1776:2806: warning: passing argument 1 of 'memcpy' makes pointer from integer without a cast [-Wint-conversion]
In file included from /opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlPiCmi.h:5:0,
from /opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:83,
from <stdin>:24:
/usr/include/string.h:42:14: note: expected 'void * restrict' but argument is of type 'long int'
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
<stdin>:1776:2841: warning: passing argument 2 of 'memcpy' makes pointer from integer without a cast [-Wint-conversion]
from <stdin>:24:
/usr/include/string.h:42:14: note: expected 'const void * restrict' but argument is of type 'long int'
<stdin>:1776:2969: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
<stdin>: In function 'Memristor_pGetMatrixPointers':
<stdin>:1782:2403: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
<stdin>:1782:2547: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
<stdin>: In function 'Memristor_pAnalTranLoad':
<stdin>:1819:3931: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast [-Wint-conversion]
<stdin>:1820:74: warning: passing argument 1 of 'aslDevFillZeroDiagQuartet' makes pointer from integer without a cast [-Wint-conversion]
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:2713:33: note: expected 'void *' but argument is of type 'long int'
ASL_FUNC_DECL_START extern void aslDevFillZeroDiagQuartet( void *, int, unsigned int, struct ahdlFuncModeParam * );
<stdin>: In function 'Memristor_pSaveRestart':
<stdin>:1846:1930: warning: implicit declaration of function 'pklAccessDouble' [-Wimplicit-function-declaration]
<stdin>:1846:2009: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type [-Wincompatible-pointer-types]
/opt/eda/cadence/SPECTRE181/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1219:39: note: expected 'struct ahdlAnalogVar *' but argument is of type 'char *'
ASL_FUNC_DECL_START extern PklError_e aslDevAvarSR( int, struct ahdlAnalogVar *, char *, char *, char *, PklJar_t * );
<stdin>: In function 'Memristor_pSaveRestartInst':
<stdin>:1849:1925: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type [-Wincompatible-pointer-types]
<stdin>: In function 'ahdlMemristorDescInstall':
<stdin>:1930:1753: warning: implicit declaration of function 'descSetDeviceType' [-Wimplicit-function-declaration]
<stdin>:1930:1871: warning: implicit declaration of function 'descSetSetContrInfoPtr' [-Wimplicit-function-declaration]
<stdin>:1930:2231: warning: implicit declaration of function 'descSetCopySignals' [-Wimplicit-function-declaration]
<stdin>:1930:3741: warning: implicit declaration of function 'descSetPrintDescription' [-Wimplicit-function-declaration]
<stdin>:1930:3851: warning: implicit declaration of function 'descSetGetNodeNamesForBranch' [-Wimplicit-function-declaration]
rm -f -rf Memristor_ufunc.c
rm -f -rf Memristor_DcFuncLoad.c
rm -f -rf Memristor_cmi_c.c
rm -f -rf Memristor_TranFuncLoad.c
rm -f -rf Memristor_func.c
rm -f -rf Memristor_TranFuncDerLoad.c
rm -f -rf Memristor_DcFuncDerLoad.c
/opt/eda/cadence/SPECTRE181/tools.lnx86/cdsgcc/gcc/6.3/bin/gcc -shared -O3 -m64 -fPIC -o obj/optimize/5.0/libahdlcmi_Memristor.so ./obj/optimize/5.0/Memristor_ufunc.o ./obj/optimize/5.0/Memristor_func.o ./obj/optimize/5.0/Memristor_DcFuncDerLoad.o ./obj/optimize/5.0/Memristor_DcFuncLoad.o ./obj/optimize/5.0/Memristor_TranFuncDerLoad.o ./obj/optimize/5.0/Memristor_TranFuncLoad.o ./obj/optimize/5.0/Memristor_cmi_c.o -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
ld: cannot find crti.o: No such file or directory
collect2: error: ld returned 1 exit status
gnumake: *** [obj/optimize/5.0/libahdlcmi_Memristor.so] Error 1
gnumake: *** Warning: File `GNUmakefile' has modification time in the future (2024-02-06 18:35:58 > 2024-02-06 18:34:40)
    Which OS distribution are you running on? What is the output of "lsb_release -a" in the UNIX terminal?
    It also looks as if "crti.o" is not installed which suggests that you don't have the glibc-devel RPM installed on Linux - you might want to run <SPECTREinstDir>/bin/checkSysConf to report anything missing.
    Also, you're using a 5-year old version of Spectre - is there a good reason for that? Not that's the root cause, unless you're using a much newer OS and maybe SPECTRE18.1 was not supported on that?
  • Sami048
    Sami048 over 2 years ago in reply to Andrew Beckett
    Hell Andrew,
    Unfortnately we are not able to update our os and software. However, we had run into a simialr issue with hspice and were able to fix the issue by modyfing the enviromental vaiable "LD_LIbrary_PATH". It looks like spectre also uses LD_LIBRARY path but it is internal to sofware and are unable to change like we were with hspice. Would you happen to know if we would be able to change the variable in spectre to redirect in order to possible fix the issue?
    Andrew Beckett over 2 years ago in reply to Sami048
    No idea, since you didn't actually answer my question about what distribution you're running on. Understanding the failure better is rather important to knowing how it might be possible to workaround it.
