  3. calcVal ?matchParams to model file section
  • Subscribers 129
  • Views 4663
MatanR
MatanR over 1 year ago
Hello.
I'm trying to run a calibration simulation in ADE.
1. Calibration test corners are different by their specific section used from the process model file.
2. Validation test corners are same as calibration but also include a variable sweep
3. due to internal variable sweeps in corner setup - several corners are generated with a suffix (for example if I sweep variable "var" in a corner called "typ" with values "a" and "b" - I get two corners generated "typ_0" and "typ_1").
I with to use calcVal to draw the right calibration test corner - my test assumes they will have the same section from the process model file (everything else is different).
I do not know how to make ?matchParams to check the model files (I know we can do ?ignoreParams "modelFiles" - but ?matchParams requires a value).
Thank you,
Matan.
