  3. Using environment variables in Model Libraries form
  • Views 9329
mazorra
mazorra over 2 years ago
I take part in a collaborative design and we are sharing design files in a repository. In order to avoid revising the ADE view everytime we simulate, we would need to define the path to the model libraries using an environment variable.
We have a similar issue with CSV files we use for PWLF sources, but these we solved including them in the repository and using include paths. However, due to IP protection we cannot include the manufacturer libraries in the repository.
We are using ADE XL at the moment but ADE Assembler is also available, would this distinction have any implication in this issue?
Thank you in advance,
José
    José,
    ADE Explorer/Assember both support UNIX env vars on the model libraries form in the same was as ADE XL (and also in the include path - this used not to be the case in the past).
  • mazorra
    mazorra over 2 years ago in reply to Andrew Beckett
    Andrew,
    what would the syntax look like? I tried $(VAR_NAME) but that didn't seem to work. Should it be skill getShellEnvVar("VAR_NAME")? Or is there another way?
    Cheers,
    José
    Andrew Beckett over 2 years ago in reply to mazorra
    Just use $VAR_NAME/path.scs for example (no parentheses around that variable name).
  • mazorra
    Great, thank you Andrew.
    José
