  3. Why is Spectre ignoring time tolerance or time step conditions...
  • Views 8250
Why is Spectre ignoring time tolerance or time step conditions from Verilog-AMS models?
DomiHammerfall
DomiHammerfall over 2 years ago
Dear community
I am using the following Verilog-AMS model to generate sharp pulses:
module my_source(MINUS, PLUS);
inout MINUS;
electrical MINUS;
inout PLUS;
electrical PLUS;
parameter real delay = 1.0u;
parameter real period = 10.0u;
parameter real amplitude = 8.0;
real out;
analog begin
@(initial_step) begin
out = 0;
end
@(timer(delay,period)) begin
out = amplitude;
end
@(timer(delay+2n,period)) begin
out = 0;
end
I(PLUS, MINUS) <+ transition(out*25e-9,0,1n);
end
endmodule
This signal is further amplified by some analog circuit. The problem is that the observed amplitude at the end of the signal chain varies over time unless I set a very strict reltol of 1e-6 or force a small maximum step size in the transient simulation, e.g. 50ps. This slows down the simulation a lot. To prevent that, I want to force the simulator to temporarily limit its step size. This can be done with the $bound_step function, but for whatever reason, Spectre seems to ignore that. So in my code I add
$bound_step(50p);
out = amplitude;
end
and then reset it after 300ns
@(timer(delay+300n,period)) begin
$bound_step(1m);
end
According to the log, the step size is not limited to 50ps and the amplitudes still vary over time. However, if a call $bound_step outside of the timer function, then Spectre does indeed use a step size of 50ps, but this is then applied for the complete simulation and thus very slow. So why is Spectre ignoring the call of $bound_step inside the timer function? Are there other ways to achieve the desired outcome?
Thanks for any suggestion.
    Whilst I'm not sure this is the right way of solving the problem, the issue is that if you use $bound_step(), you need to invoke it in every iteration and not just at the times of the event - otherwise it only sets it for a single tilmestep. It doesn't set the maximum timestep until next called.
    Instead you could have a variable in the code which is the maxstep (say) and then call $bound_step(maxstep) all the time, and have your timer blocks alter the value of maxstep.
  • DomiHammerfall
    DomiHammerfall over 2 years ago in reply to Andrew Beckett
    Dear Andwer
    Thank you very much for your help.
    Whilst I totaly agree with you that this might be not the ideal way to tackle to probelm, I can confirm that your proposed solution works. Here are the adjustments of the code for those who want to use it as well:
    real maxstep;
    analog begin
    $bound_step(maxstep);
    maxstep = 50e-12;
    end
    maxstep = 1e-3;
    end
    end
