  3. xrun error in AMS simulation
  • Views 8871
Shaheer Ashraf
Shaheer Ashraf over 2 years ago
Respected Members,
I am tring to run AMS simulation in virtuoso where i have created tb using symbol of function cell view.
Right now i am in config cell view and have followed the AMS Designer Simulation flow: But the error is coming during generate netlist step. Any help would be appreciated.
The error is:
*ERROR*: Error encountered while registering text designs in the configuration.
    Refer to the following messages and correct the errors.
xrun: *E,AMSCOMM: AMSD control block processing failed to write spice primitives to the file 'amscomm.list'. Either spectre exited before elaboration or encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
    There have been occasional reports of such errors. I would start by ensuring you're running the latest XCELIUM and SPECTRE releases, and if the problem persists, contact customer support (submit a support case after logging in).
