  3. Problem with GUI for custom calculator function
  • Views 6662
Volker T
Volker T over 2 years ago
Dear all,
I wrote a very simple custom calculator function with the following function signature:
procedure( countSamples( signal )
 <code>
) ; countSamples
I also added - in the same SKILL file - the following GUI builder information
;;;;;;;;;;;;;;;;;;;;;;;;;; GUI builder information ;;;;;;;;;;;;;;;;;;;;;;;;;;;
ocnmRegGUIBuilder(
 '(nil
  function countSamples
  name countSamples
  description "Count the number of samples avaliable for the given signal."
  category ("Custom Functions")
  analysis (nil
      general (nil
        args ( signal )
          signals (nil
                signal (nil
                      prompt "Signal"
                      tooltip "The signal vector to count the number of samples for."
        inputrange t
  outputs(result)
This is pretty much like the example provided in the Cadence Help.
However, it acts a bit weird. If I click on it in Calculator, with no signal already selected in the buffer, nothing happens. With signal already in the buffer, it nicely wraps around it (e.g. countSamples(VT("/result")) ).
There are other calculator functions like Kf() as an example, which also just have one mandatory argument. When I click on it - again with an empty buffer - it adds "Kf()" to the buffer, such that I can then enter the argument in the brackets. This is a more intuitive behaviour: action by the user like a click on the function follows action in the Calculator window.
What am I doing wrong, that my function does not behave like this as well?
    You're not doing anything wrong. The Kf() function does not have a mandatory argument, in fact it doesn't (normally) take any arguments and so it makes no sense for it to expect something in the buffer.
    For a function that must have something in the buffer, your code is correct. It's behaving as expected. Try pressing the dB20 function - that behaves the same way as your function does - it doesn't do anything unless something is in the buffer.
    Note, rather than writing the template code yourself, it's much easier to get the fx button to add it to your code for you (that's what I always do).
