  3. Cadence Run Preview Customization
  • Views 6298
HongJian
HongJian over 2 years ago
Hi all, for a particular test bench, usually before running a sim, I will have a standard operating procedure of
One time only
  1. Checking the High Performance Simulation Settings (The accuracy settings)
  2. Checking Job Policy (which is available in Run Preview currently, but I am using command mode, and it's not showing enough info)
Regular
  1. Checking the simulation files (which DSPF files I am using)
  2. Check particular Design Variables that I am interested (I actually hoping to have comment/note of all these design variables and their default value)
  3. Corners selected (which is available in Run Preview currently)
Is it possible to make a new dashboard for review these stuff in a glance using SKILL or customise the Run Preview Tab? Hope to have some pointer for relevant API. If I successfully make it, will share around here if people found useful
(I understand that this is a big stuff, feel free to break down and if it's possible to achieve one of it, you can share the relevant function with me)
    I would suggest you contact customer support about this.
