  3. bad pivoting in transient and DC simulation
  • Views 9586
FPMKh
FPMKh over 2 years ago
My virtuoso version is: ICADVM20.1-64b.CUSTISR33.26
I'm running a transient simulation using Spectre X and I get the following message regarding DC convergence:
"Notice from spectre during IC analysis, during transient analysis `tran'.
GminDC = 1 pS is large enough to noticeably affect the DC solution.
dV(MNW.RF.clk_pdet_int) = -34.2307 mV
Use the `gmin_check' option to eliminate or expand this report.
Bad pivoting is found during DC analysis. Option dc_pivot_check=yes is recommended for possible improvement of convergence."
I get the same message in the DC simulation. I tried to add the dc_pivot_check=yes option in the additional parameters of the MISC section and I got the same message above with the following warning saying the dc_pivot_check that I set is ignored.
"Warning from spectre during hierarchy flattening.
WARNING (SFE-106): "input.scs" 79: Parameter `dc_pivot_check', specified for analysis `tran', has been ignored because it is an invalid analysis parameter. Specify a valid analysis parameter and rerun the simulation. Type `spectre -h tran' to get more information on valid tran analysis parameters."
Can you please help me understand what did I do wrong and how can I successfully specify dc_pivot_check=yes? Any other suggestions to help with this bad pivoting issue?
    Andrew Beckett over 2 years ago +1
    The iC version isn't really important here since this is a Spectre message (it would be the Spectre version that's more important). However, in this case I don't think it's going to be particularly version…
    The iC version isn't really important here since this is a Spectre message (it would be the Spectre version that's more important). However, in this case I don't think it's going to be particularly version-dependent.
    You're setting the option in the wrong place. It's not a tran analysis parameter, but an option and so it's under Simulation→Options→Analog, and is in fact on the Algorithm tab .
    The bad pivoting probably isn't ultra-critical (I was going to consult Ken Kundert's The Designer's Guide to SPICE and Spectre, but unfortunately I don't have my copy at home at the moment as I've lent it to a colleague).
  • FPMKh
    Thank you, Andrew. Found it. The reason I was interested in resolving this bad pivoting was that during EMIR analysis, I was getting a convergence issue. The transient runs properly but the EMIR tool tells me DC (during transient) did not converge and so gives me an error. I thought resolving this bad pivot might help which it didn't.
