  3. spefcheck for caliber pex file
  • Subscribers 136
  • Views 6969
NXPMaheshwar
NXPMaheshwar over 2 years ago
 xdspf file syntax is checked with spefchecker but file created with calibre-pex is giving the segmentation problem. Is there any way to check this?
    Why would you be using the Quantus spefchecker tool to check a DSPF file generated by a different extraction tool? That's not what it's intended for.
  • NXPMaheshwar
    NXPMaheshwar over 2 years ago in reply to Andrew Beckett
    we are trying to run the post-layout simulation using that xdspf file
    Andrew Beckett over 2 years ago in reply to NXPMaheshwar
    Please contact customer support so that this can be investigated.
  • NXPMaheshwar
    Thanks Andrew, i heard about you from my career starting for skill features. finally able to connect to you
