  3. Unable to open the waveform file `ecg/.csv'. Ensure that...
  • Views 1944
Unable to open the waveform file `ecg/.csv'. Ensure that the specified file or directory exists.
AvaHeda
AvaHeda over 2 years ago
Hi ,
Hope you are doing well,
I need help importing the.csv file to my ade.xl.
I am facing a problem importing the csv file in the design variable, and i have attached screenshots of the errors that occurred while importing.
Can you please help me solve this asap.
Thank you,
Kind regards,
Likitha BR
030768619
    The error message suggests that you have the file name specified on the voltage source as "ecg/.csv" rather than "ecg.csv". Can you check that? You appear to have set up the Include Path correctly to reference the directory containing the file, so it just looks as if the file name is wrong (this should also be clear if you look in the netlist produced by ADE).
