  3. Problem with using a genvar in if statement in Verilog-...
  • Views 6707
Problem with using a genvar in if statement in Verilog-a
Esmee Tackx
Esmee Tackx over 2 years ago
Dear
I ran into some problems while I was trying to build a ring oscillator in verilog-a.
RTL Code:
// VerilogA for VerilogA_test, Test_interne_node, veriloga
`include "constants.vams"
`include "disciplines.vams"
module Test_interne_node(VDD, VSS, EN, out);
parameter integer N_stage = 3;
inout VDD, VSS;
input EN;
output out;
electrical out, VDD, VSS, EN;
electrical [N_stage:0] intern;
genvar i;
      for (i= 0; i <= N_stage-2; i=i+1) begin
            RDUC_INV I0(.VDD(VDD),.VSS(VSS),.In(intern[i]),.Out(intern[i+1]),.EN(EN));
            if (i == N_stage-2) begin
                  RDUC_INV I1(.VDD(VDD),.VSS(VSS),.In(intern[i+1]),.Out(out),.EN(EN));
                  //My_res #(.r(0)) R(.p(out),.n(intern[3]));
                  analog V(out,intern[0]) <+0;        // de spanning tussen deze twee nodes nul maken is ze in essentie korstluiten
            end
      end   
endmodule
The goal of the code is to build a ring oscillator using invertors I have designed using virtuoso schematic (called RDUC_INV). The code should link these oscillators in series and then feedback the last invertors output signal to the input of the first invertor, building a ring oscillator. The parameter N_stage is used so that there is a possibility to choose how big (3 invertors, 5 invertors, 7...) the oscillator can be and to be eventually used as a CDF parameter to be able to be swept while using assembler.
The problem with the code is that when using the genvar i in the if statements, it appears that i is always evaluated as zero even though it should change every run through the for loop. I tested out multiple cases to find out this is the problem
If the if statement says: if (i == N_stage-2) begin, the code inside the if statement is never executed; Whilst if the if statement says: if (i == 0) begin, the code in the if statement is executed every for loop.
I have also tried using different versions of virtuoso (ic_6.1.8.310.rc, icadvm_20.10.310.rc) and they both show the problem. I have tried to work around the problem by using  generate statements, using a constant that counts with the loop but here there are problems cause there is no analog block. I also tried just having the code inside the if statement at the complete end outside of all the loops but this makes that I need to use the parameter N_stage as bus indicator in intern[]  (intern[N_stage]). The problem with this is that it doesn't' take the value of N_stage but it does some sort of memory read. I know this because when using this statement the nets of my design show for example to be inside[181567948] but this value changes every time the code is compiled without actually changing the code.
I have added the schematic of the RDUC_INV invertor, the verilog-a file, the testbench with schematic and assembler file.
https://kuleuven-my.sharepoint.com/:u:/g/personal/esmee_tackx_student_kuleuven_be/EWBU2IF07i5PhkRxmgpDfyIBUFifI96zSMWJRP6YwMkLzw?e=sZmUlQ
Hopefully U can help me.
Kind regards
Esmee Tackx
