  3. XF Analysis: How to save transfer function from only certain...
  • Subscribers 136
  • Views 6476
XF Analysis: How to save transfer function from only certain sources?
Matthew Love
Matthew Love over 2 years ago
For the XF analysis I would like to only save a certain number of sources.
I have set "save" to "selected" but no matter what I do, all of the sources are saved and the log will print.
No outputs were found. Loosening output filter criterion to `allpub'.
I have tried every variation of the "save" statement in the input files but I cannot get anything to work.
    Andrew Beckett over 2 years ago +1
    I filed a CCR (change request) on this very topic not too long ago. It's possible to use save=lvlpub nestlvl=1 to just save top-level voltage sources, but it doesn't seem to be possible to save specific…
    I filed a CCR (change request) on this very topic not too long ago. It's possible to use save=lvlpub nestlvl=1 to just save top-level voltage sources, but it doesn't seem to be possible to save specific sources with the save statement. You might want to contact customer support (submit a case after logging in) and request that a duplicate of CCR 2741173 is filed on your behalf.
  • Matthew Love
    Matthew Love over 2 years ago in reply to Andrew Beckett
    Thanks, I'll do that then.
