  3. Tran simulation results can't be saved when using XPS MS...
  • Subscribers 136
  • Views 3622
Tran simulation results can't be saved when using XPS MS and enabling post-layout optimization?
zuiying
zuiying over 2 years ago
Hello! In post-layout simulation, I set some subcircuits to calibre (modeshift4 and SAR_logic9).
To accelerate simulation, I use XPS MS and enable post-layout-optimization:
After simulation, I find tran simulation results are not saved.
But if I disable post-layout-simulation, tran simulation results are saved successfully. What's even more strange is that if I set SAR_logic9 to none and only leave modeshift4 as calibre, then the results of tran simulation can be saved whether post-layout-optimization is enabled or not.
After repeated attempts, I find that as long as SAR_logic9 is set to calibre and post-layout-optimization is enabled, the results of tran simulation can not be saved.
What could be the reason for this?  What could be the problem with SAR_logic9  that causes such a strange phenomenon?
Thank you!
Spectre.out is as follows:
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 15.1.0.284.isr1 64bit -- 12 Nov 2015
Copyright (C) 1989-2015 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: vmware Host: vmware.silicon HostID: 7F0100 PID: 46395
Memory available: 23.3686 GB physical: 33.6546 GB
Linux : CentOS release 6.10 (Final)
CPU Type: 12th Gen Intel(R) Core(TM) i7-12700
All processors running at 2112.0 MHz
Socket: Processors
0: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
10, 11
System load averages (1min, 5min, 15min) : 2.5 %, 0.9 %, 0.8 %
This is a virtual machine
Simulating `input.scs' on vmware.silicon at 3:47:27 AM, Sun Feb 25, 2024 (process id: 46395).
Current working directory: /sim/vmware/Rmeasure8_L2_tb2/spectre/config/netlist
Command line:
/eda/cadence/MMSIM151/tools.lnx86/bin/spectre -64 input.scs \
+escchars +log ../psf/spectre.out -format psfxl -raw ../psf +ms \
+speed=3 +aps +postlayout +lqtimeout 900 -maxw 5 -maxn 5
Loading /eda/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /eda/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
Loading /eda/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /eda/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /eda/cadence/MMSIM151/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Reading file: /sim/vmware/Rmeasure8_L2_tb2/spectre/config/netlist/input.scs
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/ms#3.cfg
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/ms.cfg
Reading file: /home/vmware/IC_project/tsmc18mm_1.8v_3.3v_T-018-CM-SP-007-K3_IC61_bsim4.5_pdk_v1.3a_20170119_cfg_2_2/t018cmsp007_1_4p1/T-018-CM-SP-007/models/cmn018_assp_v1d4p1_myusage.scs
Reading file: /home/vmware/IC_project/tsmc18mm_1.8v_3.3v_T-018-CM-SP-007-K3_IC61_bsim4.5_pdk_v1.3a_20170119_cfg_2_2/t018cmsp007_1_4p1/T-018-CM-SP-007/models/cmn018_assp_v1d4p1.scs
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/digital.cfg
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/configs/analog.cfg
Reading file: /home/vmware/IC_project/R_measure/my_codecell/datastore_8_20/veriloga/veriloga.va
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.vams
Reading file: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Time for NDB Parsing: CPU = 1.05784 s, elapsed = 1.07502 s.
Time accumulated: CPU = 1.06684 s, elapsed = 1.07502 s.
Peak resident memory used = 129 Mbytes.
The CPU load for active processors is :
Spectre 0 (1.9 %) 1 (99.1 %) 2 (3.7 %)
Other
The simulator has reused the existing Verilog-A libraries for this simulation run. If you do not want to use these libraries, set the 'CDS_AHDL_REUSE_LIB' environment variable to 'NO' and rerun the simulation.
Reusing Verilog-A library /sim/vmware/Rmeasure8_L1_tb6/spectre/schematic/netlist/input.ahdlSimDB/057c7a69d261cc6b6e4ba21b94d3b817.datastore_8_20.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi_datastore_8_20.so.
Existing shared object for module datastore_8_20 is up to date.
Installed compiled interface for datastore_8_20.
Warning from spectre during circuit read-in.
WARNING (SFE-2649): Remove instance `R8<1>' in subckt `RDAC5_L1' because its terminals are connected together.
WARNING (SFE-2649): Remove instance `R8<2>' in subckt `RDAC5_L1' because its terminals are connected together.
WARNING (SFE-2649): Remove instance `R8<3>' in subckt `RDAC5_L1' because its terminals are connected together.
WARNING (SFE-2649): Remove instance `R8<4>' in subckt `RDAC5_L1' because its terminals are connected together.
WARNING (SFE-2649): Remove instance `R8<5>' in subckt `RDAC5_L1' because its terminals are connected together.
Further occurrences of this warning will be suppressed.
Reading link: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading link: /eda/cadence/MMSIM151/tools.lnx86/spectre/etc/ahdl/constants.h
Reusing Verilog-A library /sim/vmware/AFE5_wPAD_tb4/spectre/schematic/netlist/input.ahdlSimDB/bsource_d0e2ae.va.bsource_d0e2ae.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi_bsource_d0e2ae.so.
Existing shared object for module bsource_d0e2ae is up to date.
Installed compiled interface for bsource_d0e2ae.
Reusing Verilog-A library /sim/vmware/AFE5_wPAD_tb4/spectre/schematic/netlist/input.ahdlSimDB/bsource_rppoly_c38538.va.bsource_rppoly_c38538.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi_bsource_rppoly_c38538.so.
Existing shared object for module bsource_rppoly_c38538 is up to date.
Installed compiled interface for bsource_rppoly_c38538.
Reusing Verilog-A library /sim/vmware/AFE5_wPAD_tb4/spectre/schematic/netlist/input.ahdlSimDB/bsource_c7f949.va.bsource_c7f949.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi_bsource_c7f949.so.
Existing shared object for module bsource_c7f949 is up to date.
Installed compiled interface for bsource_c7f949.
Reusing Verilog-A library /sim/vmware/AFE5_wPAD_tb4/spectre/schematic/netlist/input.ahdlSimDB/bsource_cb75ce.va.bsource_cb75ce.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi_bsource_cb75ce.so.
Existing shared object for module bsource_cb75ce is up to date.
Installed compiled interface for bsource_cb75ce.
Time for Elaboration: CPU = 2.10268 s, elapsed = 2.1022 s.
Time accumulated: CPU = 3.17052 s, elapsed = 3.17735 s.
Peak resident memory used = 347 Mbytes.
Starting APS DC ...
Warning from spectre during hierarchy flattening.
WARNING (SPECTRE-18018): Analyses 'info' are not yet supported in 'Spectre XPS Mixed-signal Mode'.
Time for EDB Visiting: CPU = 1.27881 s, elapsed = 18.4091 s.
Time accumulated: CPU = 46.4279 s, elapsed = 24.6789 s.
Peak resident memory used = 690 Mbytes.
Notice from spectre.
102 warnings suppressed.
Digital Detection Vsource and Virtual Power Supply Node Summary:
Type #CC #Bulk Voltage Name
GND 4388 8926 0 0
Possible VGND 415 689 TBD AVSS
Possible BUS 410 438 TBD I3.AVDD
VPN 4298 5913 TBD I3.DVDD
To force a virtual power or ground node, add in netlist
optVPN options ms_vpn=[node_name vpn_voltage]
optVGND options ms_vgnd=[node_name]
use keyword auto_vpn if you do not know the vpn_voltage
Warning from spectre.
WARNING: 2 nodes have no driver
Notice from spectre during topology check.
No connections to node `I3.CLK'.
No connections to node `I3.D<0>'.
No connections to node `I3.EN_work'.
No connections to node `I3.FCDin'.
No connections to node `I3.I0.I0.I6.c_6150_n'.
Further occurrences of this notice will be suppressed.
Only one connection to the following 162 nodes:
Dout1<1>
Dout1<2>
Dout1<3>
Dout1<4>
Dout1<5>
No DC path from node `I3.CLK' to ground, Gmin installed to provide path.
No DC path from node `I3.D<0>' to ground, Gmin installed to provide path.
No DC path from node `I3.EN_work' to ground, Gmin installed to provide path.
No DC path from node `I3.FCDin' to ground, Gmin installed to provide path.
No DC path from node `I3.I0.I0.I6.c_6150_n' to ground, Gmin installed to provide path.
Parasitics Reduction Enabled.
(Resistors reduced by 86.78% Capacitors reduced by 53.84%).
Global user options:
reltol = 0.0001
vabstol = 1e-06
iabstol = 1e-12
temp = 27
gmin = 1e-12
rforce = 1
maxnotes = 5
maxwarns = 5
digits = 5
cols = 80
pivrel = 0.001
sensfile = ../psf/sens.output
checklimitdest = psf
save = selected
tnom = 27
scalem = 1
scale = 1
Scoped user options:
cktpreset = digital subckt=my_DPAD3
cktpreset = digital subckt=digital1
cktpreset = analog subckt=R_array3
cktpreset = analog subckt=my_APAD4
cktpreset = analog subckt=Ibias_gen4_L2
cktpreset = analog subckt=Icopy_select1_L2
cktpreset = analog subckt=OPA4_DAC1_L2_D1_SW4
cktpreset = analog subckt=SW3_L2
cktpreset = analog subckt=OPA8_DAC2_L1_SW4
cktpreset = analog subckt=BDI8_L1
cktpreset = analog subckt=RDAC5_L1
cktpreset = analog subckt=DEL4BWP7T
cktpreset = analog subckt=stcomparator6_select4_L1
Circuit inventory:
nodes 91841
bsim4 22208
bsource_c7f949 8
bsource_cb75ce 10
bsource_d0e2ae 906
bsource_rppoly_c38538 453
datastore_8_20 1
diode 258
inductor 17
vsource 44
capacitor 161953
resistor 82177
Analysis and control statement inventory:
dc 1
info 8
tran 1
Output statements:
.probe 0
.measure 0
save 1
Multithreading Enabled: 8 threads in the system with 12 available processors.
Spectre XPS Mixed-signal Mode Enabled ( speed=3 ).
Time for parsing: CPU = 40.0209 s, elapsed = 36.5208 s.
Time accumulated: CPU = 60.4128 s (1m 0.4s), elapsed = 39.2277 s.
Peak resident memory used = 958 Mbytes.
Pre-Simulation Summary
- MS Table model. VDD=1.8V used for XPS table model creation, to overwrite
tmopt options vdd=val
- MS Circuit partitions: 60.1% transistors and 28.5% nodes are identified as digital partitions.
One of the following solutions may improve the digital detection.
Manually define internal digital power supply nodes and voltages.
opt1 options ms_vpn=[VDD_DIG 1.2 VDD_DIG1 3.3]
opt2 options ms_vgnd=[VSS]
For complex device models use the MS macro model option.
opt3 options macro_mos=[pmos_subckt nmos_subckt]
Use the cktpreset=digital option to force subcircuits into digital.
opt4 options cktpreset=digital subckt=[subckt_def_name]
opt5 options cktpreset=digital inst=[subckt_inst_name]
WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
205 notices suppressed.
WARNING (SPECTRE-16830): The 'dcOp' analysis of type 'dc' is skipped in XPS flow.
WARNING (SPECTRE-16518): Arithmetic exception in analysis `dcOp' .
Total time required for dc analysis `dcOp': CPU = 0 s, elapsed = 97.0364 us.
Time accumulated: CPU = 60.4128 s (1m 0.4s), elapsed = 39.2283 s.
Peak resident memory used = 959 Mbytes.
Reading file: /sim/vmware/Rmeasure8_L2_tb2/spectre/config/netlist/input.apsdc
Warning from spectre during read of ic file `./input.apsdc'.
WARNING (SPECTRE-8301): line 479: Unknown node `I3.I0.I0.I2.I0.I0.I2.I0<1>.M1:int_d' will be ignored.
WARNING (SPECTRE-8301): line 480: Unknown node `I3.I0.I0.I2.I0.I0.I2.I0<1>.M1:int_s' will be ignored.
WARNING (SPECTRE-8301): line 481: Unknown node `I3.I0.I0.I2.I0.I0.I2.I0<1>.M2:int_d' will be ignored.
WARNING (SPECTRE-8301): line 482: Unknown node `I3.I0.I0.I2.I0.I0.I2.I0<1>.M2:int_s' will be ignored.
WARNING (SPECTRE-8301): line 483: Unknown node `I3.I0.I0.I2.I0.I0.I2.I0<1>.M8:int_d' will be ignored.
Time for dc init: CPU = 390.941 ms, elapsed = 390.908 ms.
Time accumulated: CPU = 60.8358 s (1m 0.8s), elapsed = 39.6516 s.
Peak resident memory used = 960 Mbytes.
Opening the PSFXL file ../psf/tran.tran.tran ...
Transient Analysis `tran': time = (0 s -> 1 us)
Notice from spectre at time = 0 s during IC analysis, during transient analysis `tran'.
There are 90878 IC nodes defined.
Warning from spectre at time = 0 s during IC analysis, during transient analysis `tran'.
WARNING (SPECTRE-16686): Initial condition of 0 A on node I10:Dout1[1]_VSS_flow converted into initial guess (nodeset). Initial conditions will only be accepted for inductor currents.
WARNING (SPECTRE-16686): Initial condition of 0 A on node I10:Dout1[2]_VSS_flow converted into initial guess (nodeset). Initial conditions will only be accepted for inductor currents.
WARNING (SPECTRE-16686): Initial condition of 0 A on node I10:Dout1[3]_VSS_flow converted into initial guess (nodeset). Initial conditions will only be accepted for inductor currents.
WARNING (SPECTRE-16686): Initial condition of 0 A on node I10:Dout1[4]_VSS_flow converted into initial guess (nodeset). Initial conditions will only be accepted for inductor currents.
WARNING (SPECTRE-16686): Initial condition of 0 A on node I10:Dout1[5]_VSS_flow converted into initial guess (nodeset). Initial conditions will only be accepted for inductor currents.
WARNING (SPECTRE-16255): Initial condition of 3.48554 nV between nodes I3.CLK and 0 converted into initial guess (nodeset) because there is no capacitive path to ground.
WARNING (SPECTRE-16255): Initial condition of 3.48554 nV between nodes I3.D<0> and 0 converted into initial guess (nodeset) because there is no capacitive path to ground.
WARNING (SPECTRE-16255): Initial condition of 3.48554 nV between nodes I3.EN_work and 0 converted into initial guess (nodeset) because there is no capacitive path to ground.
WARNING (SPECTRE-16255): Initial condition of 3.48554 nV between nodes I3.FCDin and 0 converted into initial guess (nodeset) because there is no capacitive path to ground.
WARNING (SPECTRE-16255): Initial condition of 3.48554 nV between nodes I3.I0.I0.I3.c_22536_n and 0 converted into initial guess (nodeset) because there is no capacitive path to ground.
Finding DC approximate solution failed. Try again with try_fast_op set to no.
Trying Fast DC for nodesets..
***** First stage DC finished in 0.057 sec
DC simulation time: CPU = 2.97655 s, elapsed = 1.36009 s.
Important parameter values:
start = 0 s
outputstart = 0 s
stop = 1 us
step = 1 ns
maxstep = 10 ns
ic = all
useprevic = no
skipdc = no
reltol = 10e-06
abstol(V) = 1 uV
abstol(I) = 1 pA
temp = 27 C
tnom = 27 C
tempeffects = all
errpreset = conservative
method = trap
lteratio = 10
relref = alllocal
cmin = 0 F
gmin = 1 pS
rabsshort = 1 mOhm
Output and IC/nodeset summary:
save 8 (current)
save 373 (voltage)
tran: time = 26.5 ns (2.65 %), step = 10 ns (1 %)
tran: time = 76.5 ns (7.65 %), step = 10 ns (1 %)
tran: time = 126.5 ns (12.6 %), step = 10 ns (1 %)
tran: time = 176.5 ns (17.6 %), step = 10 ns (1 %)
tran: time = 226.5 ns (22.6 %), step = 10 ns (1 %)
tran: time = 276.5 ns (27.6 %), step = 10 ns (1 %)
tran: time = 326.5 ns (32.6 %), step = 10 ns (1 %)
tran: time = 376.5 ns (37.6 %), step = 10 ns (1 %)
tran: time = 426.5 ns (42.6 %), step = 10 ns (1 %)
tran: time = 476.5 ns (47.6 %), step = 10 ns (1 %)
tran: time = 526.5 ns (52.6 %), step = 10 ns (1 %)
tran: time = 576.5 ns (57.6 %), step = 10 ns (1 %)
tran: time = 626.5 ns (62.6 %), step = 10 ns (1 %)
tran: time = 676.5 ns (67.6 %), step = 10 ns (1 %)
tran: time = 726.5 ns (72.6 %), step = 10 ns (1 %)
tran: time = 776.5 ns (77.6 %), step = 10 ns (1 %)
tran: time = 826.5 ns (82.6 %), step = 10 ns (1 %)
tran: time = 876.5 ns (87.6 %), step = 10 ns (1 %)
tran: time = 926.5 ns (92.6 %), step = 10 ns (1 %)
tran: time = 976.5 ns (97.6 %), step = 10 ns (1 %)
Number of accepted tran steps = 104
Post-Transient Simulation Summary
- DC analysis takes more than half of total simulation time. To speed up, consider
add +fastdc on command line
add +msdc=ms on command line
reuse previous ic file
- Non-default settings that could significantly slow down simulation
errpreset = conservative, default moderate
reltol = 10e-06, default 100e-06 (conservative)
- 94.13 % simulation time spent in analog partition. Consider force more circuit blocks to digital, or use more aggressive APS options.
5.87 % simulation time spent in digital partition.
During simulation, the CPU load for active processors is :
Spectre 0 (19.0 %) 1 (65.0 %) 2 (24.0 %) 3 (32.7 %)
4 (14.2 %) 5 (12.0 %) 6 (12.0 %) 7 (12.0 %)
8 (5.4 %) 9 (4.1 %) 10 (2.2 %)
Other
Initial condition solution time: CPU = 2.97655 s, elapsed = 1.3602 s.
Intrinsic tran analysis time: CPU = 2.85357 s, elapsed = 1.34089 s.
Total time required for tran analysis `tran': CPU = 6.77197 s, elapsed = 4.59517 s.
Time accumulated: CPU = 67.1968 s (1m 7.2s), elapsed = 43.8328 s.
Peak resident memory used = 1.06 Gbytes.
709 warnings suppressed.
Aggregate audit (3:48:11 AM, Sun Feb 25, 2024):
Time used: CPU = 67.2 s (1m 7.2s), elapsed = 43.8 s, util. = 153%.
Time spent in licensing: elapsed = 47.2 ms.
Peak memory used = 1.06 Gbytes.
Simulation started at: 3:47:27 AM, Sun Feb 25, 2024, ended at: 3:48:11 AM, Sun Feb 25, 2024, with elapsed time (wall clock): 43.8 s.
spectre completes with 0 errors, 32 warnings, and 24 notices.
    I've seen this kind of symptom in the very distant past where the results browser isn't showing the actual simulation results. However, trying to guess what's causing it when the simulator version you're using is 9 years old is not really a good use of my time (I'm guessing that your IC version is similarly old?)
    Please run with something more recent. If the problem persists with versions from the last year, then report this to customer support (submit a case after logging in). It is highly likely that whatever is the root cause will have been fixed by now (since I've not seen this behaviour for a very long time).
