  3. Detecting when a Job Policy form is opened or modified
  • Subscribers 136
  • Views 6077
stefanwerleman
stefanwerleman over 2 years ago
I am attempting to connect to the event triggered when a user opens the Job Policy Setup Form via ADE to execute certain modifications to the form itself, such as hiding or disabling some input fields.
Similar to how the `postInstall` signal detects when an ADE window has been opened, I would like to utilize signals or triggers to accomplish this task. I understand how to directly modify the field when I have a `formStruct`, but now I need to establish a connection to trigger these modifications when the event occurs. I know I can use the `hiRegTimer()` as a last resort, but I would like to avoid this approach.
Any idea on how to achieve this?
    Andrew Beckett over 2 years ago +1
    There isn't support for this - nor a trigger to do so. There have been similar requests before, so I suggest you contact customer support (submit a case after logging in). Andrew
