  3. Liberate error ERROR (LIB-465)
  • Subscribers 136
  • Views 6694
BIGO
BIGO over 2 years ago
I've tried to execute a tcl scrpit using command line of Liberate, and it show this error.
My code is :
exec mkdir -p ${rundir}/LDB
exec mkdir -p ${rundir}/LIBRARY
exec mkdir -p ${rundir}/DATASHEET
### Define temperature and default voltage ###
set_vdd vdd 0.65
set_gnd gnd 0
set_operating_condition -voltage 0.65 -temp 27 -supply_name vdd
## Load template information for each cell ##
source ${rundir}/TEMPLATE/template.tcl
## Load spice models ##
# Command and options to call the external SPICE simulator
set_var extsim_cmd spectre
# Option to be passed to SPICE simulator
set_var extsim_cmd_option "+spice"
# Option to be used during characterization
set_var extsim_option "runlvl=5"
set_var extsim_leakage_option "gmindc=1e-14 pivtol=1e-15"
#set_var extsim_save_failed all
set_var reset_negative_power 1
set_var extsim_deck_header ".hdl $rundir/MODELS/nGAAFET/bsimcmg_nmos.va\n.hdl $rundir/MODELS/pGAAFET/bsimcmg_pmos.va"
define_leafcell -extsim_model -type nmos_soi -pin_position {0 1 2 3 4} bsimcmg_nmos
define_leafcell -extsim_model -type pmos_soi -pin_position {0 1 2 3 4} bsimcmg_pmos
set_var extsim_flatten_netlist 0
# The external simulation engine is used for all simulations (char_library option -extsim must be specified)
set_var extsim_exclusive 1
set spicefiles_spectre $rundir/NETLIST/$cell.scs
lappend spicefiles_spectre $rundir/MODELS/nGAAFET/bsimcmg_nmos.scs
lappend spicefiles_spectre $rundir/MODELS/pGAAFET/bsimcmg_pmos.scs
read_spice -format spectre $spicefiles_spectre
## Characterize the library for NLDM (default), CCS and ECSM timing.
char_library -ccs -ecsm -extsim spectre -cells $cell -thread 10
## Save characterization database for post-processing ##
write_ldb ${rundir}/LDB/$cell.ldb
## Generate a .lib with ccs, ecsm ###
write_library -overwrite -ccs ${rundir}/LIBRARY/${cell}_ccs.lib
write_library -overwrite -ecsm ${rundir}/LIBRARY/${cell}_ecsm.lib
write_library -overwrite ${rundir}/LIBRARY/${cell}.lib
## Generate ascii datatsheet ###
write_datasheet -format text ${rundir}/DATASHEET/$cell
The error is:
ERROR (LIB-465): (char_library): The Program will exit now, as char_library is not supported in interactive mode.
Finished Liberate Execution.
    You posted this in the wrong forum - that forum is for feedback, questions and suggestions related to the forums themselves, not for technical questions. I've moved this to a more appropriate place.
  • Guangjun Cao
    Guangjun Cao over 2 years ago
    The common cause for LIB-465 error is missing Spectre licenses. Do you see additional messages(warning or error) in the logfile before this error?
    Guangjun
