  3. Temperature simulation in ADE Explorer/Assembler
  • Subscribers 137
  • Views 3974
TzuYun Chang
TzuYun Chang over 2 years ago
Hi, I am quite new to the Virtuoso software and I am trying to sweep the temperature to see the thermal-dependent transient response of the circuit. I have seen that you could use Tools->Parametric Analysis and I can find that interface in ADE explorer. However, I don't know how I can set this globally as when no instance is selected, no parameter is shown.
  • DomiHammerfall
    DomiHammerfall over 2 years ago
    In ADE Explorer/Assembler, you simply add the temperature as a design variable. To do so, simply create a variable with the name temperature as shown below.
