  3. Joules Power Calculator v22.1 lecture pdf is unavaliabl...
  • Subscribers 136
  • Views 5700
Joules Power Calculator v22.1 lecture pdf is unavaliable
AndyWangsh
AndyWangsh over 2 years ago
Same as subject, Joules Power Calculator v22.1 lecture pdf is unavailable
Please find a way to fix the URL, thank you!
    Two things:
    1. Joules is a "Digital Implementation" tool and so the Custom IC Design forum is not the correct forum - although asking about training materials on the forums is not the correct place either...
    2. I've no idea why "v22.1 lecture pdf" you're talking about? Is this through the online training material on http://support.cadence.com ? If so, please submit a support case (Cases->Submit at the top). Having done a quick search of the training course, I'm pretty certain that must be what you're talking about...
