  3. how to write log while using features of Advanced Optimization...
  • Subscribers 136
  • Views 5766
how to write log while using features of Advanced Optimization ?
Monarch03116
Monarch03116 over 2 years ago
I would like to record how many times the feature "Advanced Optimization" used by user ?
Hope to have record while user click "Advanced Optimization" and "run" the simulation, not just clock "Advanced Optimization" without "run".
just want to differentiate the difference in between "Single run, Sweep and Corners" and "Advanced Optimization" ?
    You could use a "preRun" trigger something like this to do this - you would then need to adapt the code to control where you record it...
    procedure(abExamplePreRunTrigger(sess sdb mode testName)
        printf("Run mode is %s\n" mode)
    procedure(abAddExamplePreRunTrigger(sess)
        axlSessionConnect(sess "preRun" 'abExamplePreRunTrigger)
    procedure(abSetupExamplePreRunTrigger()
        ; Ensure we only register the trigger once
        unless(abSetupExamplePreRunTrigger.registered
            axlSessionRegisterCreationCallback('abAddExamplePreRunTrigger)
            abSetupExamplePreRunTrigger.registered=t
    Load this code and then call abSetupExamplePreRunTrigger() .
