  3. Device Check Asserts that only apply within a specific time...
  • Subscribers 136
  • Views 6345
Device Check Asserts that only apply within a specific time window
dconnern33
dconnern33 over 2 years ago
Hello Everyone,
I have a question as to how one could implement a general device check/assert where the expression being checked only applies if the violation time within a time value value.
For example : lets say I have an assert statement that does the following for a transient simulation condition
Check01 assert sub=device1  anal_types=[tran] expr="V(g,s)<X & V(d,s)>Y)" message="device 1 violated Vds under condition 1" level=warning
The above statement will issue warning whenever any signal meets the criteria specified in the expression. Now I know that I can filter the above check so that it only applies for violations that are greater than time Tmax using the duration=Tmax modifier. What I want to do is something more flexible.
I am looking for a way of configuring the checks so that they only apply for durations that are within specific time windows So for example, If I have a very short time pulse I want to allow for a looser check, if the violation time is somewhat longer I want another check, and so on ..There is the check_windows=[t1 t2] modifier which does what I want  but it only applies to specific time points for the specific simulation that I am running. I would like to find a way to implement the check_windows functionality but in a way that is generic and can be used by any designer running a transient simulation in spectre.
