  3. Assembler Global Optimization
  • Subscribers 136
  • Views 6165
sram17
sram17 over 2 years ago
I'm getting the following error:
ERROR (ASSEMBLER-1713): You are attempting to run 1481016621 design points in ADE Assembler.  This exceeds a hard limit of 1e+06 on the size of the run.  Reduce the number of points to be run.
I dont recall getting this error before. What changed and how can the limit be overcome? Thanks!
Shriram
  • sram17
    I think I found the issue: I did not choose Global Optimization from the pull-down and tried to run Single Run instead ... Problem solved!
