  3. Post-layout simulation without spectre view in transistor...
  • Subscribers 130
  • Views 6704
Post-layout simulation without spectre view in transistor cell
Javadgo
Javadgo over 1 year ago
I'm new to extraction and post-layout simulation. I can extract parasitics and generate "av_extracted" view. I can also do post-layout simulation using ADE-L>Setup>Environment>Switch View List and adding "av_extracted" before "spectre".
However, I want to use a config file for more control over the view for each block. The problem is, when generating the config file, I noticed that the transistors model in my PDK do not have spectre view. Using other views like "auCdl" or "auLvs" will not give me the correct answer in my post-layout simulation.
Any suggestion to solve this issue?
    How did you run pre-layout simulation?
    You might want to contact the foundry that provided the PDK.
  • Javadgo
    Javadgo over 1 year ago in reply to Andrew Beckett
    Thanks Andrew,
    I just put the transistor from PDK into my testbench, and the simulation is running smoothly!
    Is there a way for me to examine in detailed how the spectre is using these transistors in my pre-layout simulation, perhaps through a netlist or similar means?
    Andrew Beckett over 1 year ago in reply to Javadgo
    Which transistor? Are you instantiating lvtnfet or lvtnfet_b? Maybe there's a difference. I don't know enough of the details of this specific technology - so that's why contacting the foundry makes sense.
  • Javadgo
    Got it, Andrew. I'll reach out to the foundry. Thanks!
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago in reply to Javadgo
    I happen to be familiar with this type of PDK. You should probably make sure that you are using the templates from the PDK for your configs. As a workaround, you might also add SimMosfetAccurate to both the View List and the Stop List.
  • Javadgo
    Javadgo over 1 year ago in reply to Frank Wiedmann
    Thank you, Frank! Your suggestion to add SimMosfetAccurate to both the View List and Stop List worked perfectly for me. Now I can see the post-layout result. I'll also reach out to the foundry to inquire about the official template, if there is any.
