  3. Negative time step with ADE_L transient simulation
  • Subscribers 136
  • Views 5446
ccsim
ccsim over 2 years ago
I have an application that is calling external c-code in using verilog-A for a transient circuit simulation. The c-code saves a log file that reports the time steps the simulation sent it, and I've noticed that sometimes the time-steps are negative.
The c-code is tracking the state of a circuit between function calls. I need to know the correct behavior to take when Cadence asks for a negative time step.
Should I run the system backwards in time? i.e. if I have a resistor in series with a capacitor in my c-code, and the resistor is biased so that current flows through the resistor and onto the capacitor, should I remove charge from the cap during a negative time step? Or should I ignore that time step and keep the initial state of my circuit?
What is the solver doing that it needs to take negative time steps, and are they avoidable?
Thanks!
