  3. MOSFET dimension in schematic and LVS mismatch in TSMC 180nm...
  • Subscribers 129
  • Views 1555
MOSFET dimension in schematic and LVS mismatch in TSMC 180nm I/O library
JadeCircuit
JadeCircuit over 1 year ago
I am using an analog I/O pad library from TSMC180nm. The schematic view is imported from a Spice file. The layout is from a GDS file.
I attached an example of a pmos showing this issue. In the schematic view, the l and w are set to 0.4u and 54u to match the dimensions in the layout. However, the dimensions become other numbers when running LVS therefore giving LVS errors.
If I change the dimensions in the schematic, the numbers shown in LVS will also change, but they never match the numbers in the schematic.
Any help is appreciated!
  • RobMan
    RobMan over 1 year ago
    Looks like the schematic netlist might be in error.
      Check the netlist. What values are present? Are parallel devices merged?
      Check CDF for auCdl netlisting. W/L might not netlist the values as you see on the form.
      Why not LVS against the source spice?
