  3. Issue using vpwl
  • Subscribers 136
  • Views 7873
Issue using vpwl
spatz
spatz over 2 years ago
I want to create a linear ramp with the vpwl source and transient analysis.
I did set the pairs (Time 1 = 0s, Voltage 1 = 0s) and (Time 2 = 1us, Voltage 2 = 1V) and I expect a linear ramp from the first pair to the second pair. I measure the voltage at the positive terminal of the vpwl source.
Problem: The source does not ramp, the measured voltage remains at 0V.
Spectre Version: 21.1.0.460.isr10 64bit
Virtuoso Version: IC6.1.8-64b.500.27
Simulation Setup
  • spatz
    I did change the source from vpwl to vsource (type:pwl) and now it works as expected.
    Andrew Beckett over 2 years ago in reply to spatz
    That's odd. Can you show what the input netlist (input.scs) is with vpwl being used?
  • spatz
    spatz over 2 years ago in reply to Andrew Beckett
    I cannot replicate the issue described above.
    The testbench with vpwl source is working now too.
    ¯\_(ツ)_/¯
