  3. Maestro - output expression values with suffix notation...
  • Subscribers 136
  • Views 1463
Maestro - output expression values with suffix notation instead of engineering
firebolt3
firebolt3 over 2 years ago
Output expression values like clip signal from 4m to 5m will convert them to engineering notation. 4m to 0.004 or 4n to 4e-09. Is there a way to retain values with suffix only? This is easier for repeated expression edits. Thanks.
virtuoso version ICADVM20.1-64b.500.34
    Andrew Beckett over 2 years ago +1
    There's a long-standing enhancement request for this, Cadence Change Request #835779. I suggest you contact customer support and request that a duplicate is filed on your behalf (this increases the likelihood…
    There's a long-standing enhancement request for this, Cadence Change Request #835779. I suggest you contact customer support and request that a duplicate is filed on your behalf (this increases the likelihood of it being implemented).
