  3. Maestro - save right click menu order from results tab
  • Subscribers 136
  • Views 1070
firebolt3
firebolt3 over 2 years ago
Is there a way to save right click menu order from results tab after customizing it? This will avoid re-customizing menus in newer workspaces?
virtuoso version ICADVM20.1-64b.500.34
    Andrew Beckett over 2 years ago +1
    No, but you can move the .cadence/RMBCustomization directory (where the changes get saved to) to another .cadence directory (for example the ~/.cadence directory) - in which case it would get picked up…
    No, but you can move the .cadence/RMBCustomization directory (where the changes get saved to) to another .cadence directory (for example the ~/.cadence directory) - in which case it would get picked up in any workspace you start in (unless overwritten locally).
