  3. probe internal bus voltages
  • Subscribers 136
  • Views 6677
sunil09
sunil09 over 2 years ago
I would like to probe 4sets of 8bit buses internal to a block (internal ADC outputs) from test bench level. At the test bench level, i will then be applying these bus voltages/signals to a veriloga block for further processing. Now, i am probing one internal net at a time using  a deepprobe each  by setting
heirarchical node to ADC.DIG1\<0\> on the deepprobe
May I know if there is a way to probe the whole bus at once, rather than probing one net at a time. That could be something like setting
heirarchical node to ADC.DIG1\<8\:0\>
Thank you!!
    The deepprobe component doesn't (currently) support buses. There's an enhancement change request, CCR #1676745 which is requesting this - I see there's a proposed fix, but I don't know yet how this is intended to work.
    For now, your best bet is probably to use out-of-module references within a Verilog-A module (perhaps using a genvar to iterate over the bus to create the connections) to do this. I don't have an example to hand of doing this though...
  • sunil09
    sunil09 over 2 years ago in reply to Andrew Beckett
    Thank you Andrew!! Will try that.
    so this is how far i managed to get..below is the verilog a code..
    `include "constants.vams"
    `include "disciplines.vams"
    `define TOTAL_BITS 4
    module deepprobe_4bits(NET);
    output [`TOTAL_BITS-1:0] NET;
    electrical [`TOTAL_BITS-1:0] NET;
    parameter string hierBusNet = "testBlock.net";
    string busIter;
    string netName;
    //electrical netName;
    analog begin
    generate i (0, `TOTAL_BITS-1) begin
    $swrite(busIter,"\\<%d\\>",i);
    netName = {hierBusNet, busIter};
    $strobe(netName);
    V(NET[i]) <+ V(netName);
    end
    end// analog
    endmodule
    When i run this code, I get an error saying "no discipline was specified for `netName'." - this is for the line highligted in yellow.
    Now,  if i include the line commented out (highlighted in grey), i get  "Attempting to redefine identifier 'netName'. Remove the extra definition or use a different identifier"
    if i remove string netName, i get "Encountered invalid type conversion for `netName' (`string' to `node')"
    Not sure how to convert  from string to electrical, i think this is what i am missing.
    Thank you!!
